LoRaWan 1 ch Gateway Module Based on ESP32 - issues and questions
edited December 2023 in Announcements
Can't extract .rar file: I have downloaded this file but it will not extract on windows and unix computers: https://www.elecrow.com/download/product/CRT01262M/ESP-Lora_Factory_program.rar
Maybe provide a .zip version?
I made a mistake entering the node ID on the initial startup page (I didn't fill in 16 bytes, but the software accepted it anyway), and I can't fnd how to return to the configuration page to try again.
How do I go back to the factory startup screen?
  • Hello @tecsol ,
    Here's the .zip version:
    This is an embed external element. It can be deleted using the delete key or the backspace key. To view the full element, press the preview button below.
    File
    ESP-Lora_Factory_program.zip
    96.99 KB
  • The zip file was readable. thanks.
    By studying the source code, I have found that you hold the upper push button, labelled "BOOT" and not the lower button labelled "RESET" for 3 seconds to trigger a configuration reset. This puts the WiFi into Access Point mode, and you can connect with your phone/tablet/lap top and set the configuration. The Lorwan Id must be 16 bits, but the unit does not check this!
  • Hello Nadirbhai, thank you for your comments. Were they edited (or written) by Chat GPT?
    I has hoping for functional advice and code examples from Elecrow that assist and demonstrate setting up and using thier product.
