5" esp32 display UART to/from Arduino
Hi I have a project using UART to get data from an arduino board. But the diplay get so busy so the touch stop working. i recseive every 500ms. Is this normal or have i set something up wrong.
//Hans
Serial2.begin(115200, SERIAL_8N1, 43, 44); // Initiera UART2 för kommunikation med Arduino Mega.
  if (Serial2.available() > 0) {
    // Läs inkommande data från UART2 (RX: IO44, TX: IO43).
    String data = Serial2.readStringUntil('\n');
    // Analysera strängen för att få variablerna
    float voltage_value = getValue(data, 'V');
    float current_value = getValue(data, 'I');
    float forward_power_value = getValue(data, 'FP');
    float reverse_power_value = getValue(data, 'RP');
    float temperature_value = getValue(data, 'T');
    float VA = getValue(data, 'VA');
    float efficency = getValue(data, 'Eff');
    float SWR = getValue(data, 'SWR');
  • Hello @SM0PYH
    Have you connected the GND of the esp32 uart port to the GND of the arduino?
    Is there any error message?
  • Hi
    Yes it is connected and no errors.
    I send data from the arduino.
    If i sent with 5s interval it works "OK" but thats is far to slow for my purpose.
    I am using the USB connection to my coputer at the same time to see whats happening, could that influence?
  • Hi it was a misstake by me in my code :-( sorry....
    The call for reading did happend without any delay at all. seems to work now. i will do some more testing
  • Still not get it to work.
    Should the settings for UART be set like this? ( I am still trying to get data from an Arduino)
    Serial1.begin(115200, SERIAL_8N1, 43, 44); // Initiera UART2 för kommunikation med Arduino Mega.
    Then serial monitor via USB is also not possible?
