How to install the factory demo firmware with flash download tool?
edited September 11 in ESP32 & Lora
1. Preparation:
  • USB C cable
  • Laptop/PC
  • ESP32 Display
Check whether the materials on the PCBA board are defective. Such as less material, false welding, tin and other bad phenomena.
  • Firmware files
  • For ESP32 dispaly:
  • For ESP terminal:
  • Flash download tool
2. Flash the firmware
Step1 Connect the ESP32 display to the laptop/PC with USB-C cable. The power indicator will light up.
Step2 Open the flash download tool.
For the 2.4’’/2.8’’/3.5’’ ESP32 display, the chip select ESP32:
For the ESP terminal and 4.3’’/5.0’’/7.0’’ ESP32 display, the chip select ESP32-S3:
Step3
①Choose the firmware files;
②Enter the address:
  • For the 2.4’’/2.8’’/3.5’’ ESP32 display:
boot_app0.bin------0xe000
xxxx.ino.bin--------0x10000
xxxx.ino.bootloader.bin------0x1000
xxxx.ino.partitions.bin-------0x8000
  • For the ESP terminal and 4.3’’/5.0’’/7.0’’ ESP32 display:
xxxx.ino.bootloader.bin------0x0
③Check the firmware files;
④Select the correct port number;
⑤Click “Start” to download
Step4 Press and hold the boot button, and then press the reset button to go into the flashing mode.
Step5 After the download is complete, blue FINISH will be displayed, and the progress bar at the bottom shows that it has come to an end.
Step6 Press the reset button to show the demo.
Back to FAQs
