Pi Pico Project Enhancement
Please consider the following Project Enhancement:
For projects that have a sensor, consider capturing the data from the sensor to a file. For example, for the Laser Sight project, the code was modified to write the Aimed Time, the date and the time to file. This should encourage users to spend more time with a project to accumulate data to analyze, e.g., determine their average Aim Time or plot the Aim Time over Date and Time. The code for the Laser Sight Project:
from machine import Pin,ADC,PWM
from time import sleep
import utime as time
rtc = machine.RTC()
timestamp=rtc.datetime()
timestring="%04d-%02d-%02d %02d:%02d:%02d"% (timestamp[0:3] + timestamp[4:7])
photo = 0              # ADC0 multiplexing pin is GP26
LaserPin = 15          #Red laser transmitter
Led_R = PWM(Pin(11))
Led_G = PWM(Pin(12))
Led_B = PWM(Pin(13))
Led_R.freq(2000)
Led_G.freq(2000)
Led_B.freq(2000)
def setup():
   global Laser
   global photo_ADC
   photo_ADC = ADC(photo)
   Laser = Pin(LaserPin,machine.Pin.OUT)
   Laser.value(0)
def loop():
   aim_time = 0
   while True:
       Laser.value(1)
       Led_R.duty_u16(0)
       Led_G.duty_u16(65535)
       Led_B.duty_u16(0)
       print("time:","{:.1f}".format(aim_time))
       sleep(0.1)
       aim_time += 0.1
       if photo_ADC.read_u16() < 15000:    # Hit by a red laser, the light flashes
           print("Aimed:")
           print ("{:.1f}".format(aim_time))
           file = open ("laser sight.txt", "a")
           print(type(file))
           results = "Aim time: " + str("{:.1f}".format(aim_time)) +" (in seconds) " + "Date and Time: " + timestring + "\n"
           file.write(results)
           file.close()
           aim_time = 0
           for i in range(10):
               Led_R.duty_u16(65535)      # red light
               Led_G.duty_u16(0)
               Led_B.duty_u16(0)
               sleep(0.1)
               Led_R.duty_u16(0)
               Led_G.duty_u16(0)
               Led_B.duty_u16(65535)      # blue light
               sleep(0.1)
           sleep(2)
import os
os.listdir()
if __name__ == '__main__':
   setup()
   loop()
