Soil moisture sensor abnormality
I am continuously getting the warning "Soil moisture sensor abnormality". The sensors sits in the soil of the pot between the water outlet and the plant. It is inserted up to the marked line. It seems that the sensor gives good readings since values increase when watered. Directly after watering values increase and then decrease a bit. But this seems normal to me.
What are the reasons for this warning? I tried to move the sensor and checked the connection. It seems good.
Hector
  • It sounds like the warning might be triggered by fluctuations in moisture levels, which can happen after watering. Even though the sensor shows normal readings, the system may be sensitive to rapid changes or slight connection issues. Ensure the sensor is properly calibrated and try cleaning it for accuracy.
  • How do you calibrate the sensor?
  • edited October 2025
    Hi Hector,
    It sounds like your soil moisture sensor is functioning correctly based on your description the readings rise after watering and gradually decrease as the soil dries, which is expected behavior. The warning “Soil moisture sensor abnormality” is often triggered not by the readings themselves, but by temporary signal fluctuations, calibration issues, or connection inconsistencies.
