10.1" HA panel,when I try to play music through Home Assistant on the device,there is no sound... ?
Question:
I have connected the included speakers, set the volume to 100% and they work fine from the settings panel; however, when I try to play music through Home Assistant on the device (called "PWA (Chrome on Linux)") there is no sound... ?
Answer:
Please ask the customer to update both the panel firmware and the Home Assistant companion add-on to their latest versions. Once both are up to date, they should enable audio in the companion add-on’s settings and try playing music again.
Even if the speakers work in the panel’s settings, audio from Home Assistant playback still needs to be enabled separately in the add-on.
