Power Distribution on Compact IoT Boards – Are Power Planes Always Necessary?
With more projects using compact IoT boards, wireless modules, sensors, displays, and motor drivers, power distribution is becoming an important part of PCB design.
One thing I have noticed is that we often spend a lot of time selecting the right regulator and power supply, but give less attention to the copper paths carrying power across the PCB.
For example, imagine a board with an ESP32, a display, several sensors, and a motor driver. The regulator may be rated for the required current, but if the copper path between the supply and the load is too narrow or unnecessarily long, voltage drop and localized heating can become problems.
This is where power planes and copper pours can help. A wider copper area can provide a lower-resistance path and distribute current across different parts of the board. But using a power plane everywhere is not necessarily the best solution.
A few things are worth considering during layout:
1. Look beyond the total copper area
A large copper pour can still have narrow sections around vias, connectors, mounting holes, or other components. These restrictions may become bottlenecks for current.
2. Consider copper thickness
The choice between 1 oz and 2 oz copper can affect resistance and current-carrying capability. However, increasing copper thickness is not always necessary; sometimes improving the current path geometry is sufficient.
3. Pay attention to different voltage rails
A board may distribute 12 V, 5 V, 3.3 V, or 1.8 V supplies. When multiple rails share an internal layer, each copper region needs enough space and suitable clearance from the others.
4. Don't overlook thermal performance
Power MOSFETs, regulators, and motor drivers can generate considerable heat. Copper areas and thermal vias can help spread heat, but the layout still needs to be evaluated against the actual thermal requirements.
5. Review the layout after routing
Signal traces and vias can change the shape of a copper plane. A power path that looked sufficiently wide during the initial layout may become restricted after routing is complete.
I have been exploring these PCB layout and manufacturing considerations while working on technical topics at PCBCool. It is interesting how small layout decisions can influence the performance of an otherwise well-designed power circuit.
I'm curious how other hardware developers approach this:
  • For compact IoT or ESP32-based projects, do you generally prefer a dedicated power plane, or are copper pours and wider traces sufficient?
  • At what point do you start considering thicker copper?
  • Have you ever encountered unexpected voltage drops or heating caused by the PCB layout rather than the power supply itself?
Would be interesting to hear some real-world experiences, especially from people designing battery-powered or multi-rail embedded boards.
