Do DIS02170A have the capability to run in debug mode with break points in eclipse?
Question: "Do these panels have the capability to run in debug mode with break points in eclipse? Is there another serial driver I need to use?"
Answer:
"Unfortunately, this board does not support JTAG debugging with breakpoints via Eclipse,
If hardware breakpoint debugging is essential for your project, this board's fixed pin assignment doesn't support it via any of the standard ESP32-S3 debug paths (onboard USB or default JTAG pins). sorry this isn't the answer you were hoping for."
