DIS08070H:The screen has 3 4 PIN terminals and 2 2-PIN terminals but came with only 1 4pin cable....
edited May 14 in Elecrow HMI Display
Question:
"The screen has 3 4 PIN terminals and 2 2-PIN terminals but came with only 1 4pin cable.... Where can I get other cables so I can use this screen? "
Answer:
"Using this screen doesn't necessarily require connecting these interfaces. You only need to connect them when you need to use it.
These interfaces are generally used to connect sensors or other devices. If you buy a sensor, it usually comes with a cable, so you don't need to buy a separate cable.
Our website has Crowtail series products that can connect to some 4-pin interfaces:
https://www.elecrow.com/catalogsearch/result/?q=crowtail"
