CRV12615Y001: How do I display three different screens (plus my computer screen)?
Usually, There are only 1 way to make the CrowView Yoga and your laptop screen display three different screens totally.
If your laptop has an HDMI port and a Type-C port with DP (DisplayPort) or Thunderbolt function, you can use the following method:
• a. Connect one end of an HDMI cable to your laptop’s HDMI port, and the other end to Yoga’s HD1 port (must be HD1 only).
• b. Use a full-function Type-C cable to connect your laptop’s Type-C port to either of the Yoga’s Type-C1 or Type-C2 ports (both are fine).
• c. Set the Yoga to “Alone” mode.
(If the power supply to the Yoga is unstable, please use a power adapter to provide power. Connect a cable from the adapter to the other Type-C port on the Yoga.)
