HMI Advance esp32-P4 series product ESPHome
I have the 5inch display and the ESPHome software for this is not very good yet. You cannot flash wirelessly yet, just over console, and that takes some physical reboots to be successful. This was using the provided Esphome example on github.
The display is not centered on the screen, it is shifted about 15 pixels to the right, and the ones on the far right wrap to the other side of the screen.
The performance is a nice improvement.
Some of the errors I am seeing.
[D][esp-idf:000][sdio_write]: E (77309) sdmmc_io: sdmmc_io_rw_extended: sdmmc_send_cmd returned 0x109
[D][esp-idf:000][sdio_write]: E (77309) H_SDIO_DRV: sdio_get_tx_buffer_num: err: 265
Dear mc85,
Hope you are doing well. Thank you for your support of us.
We apologize for the inconvenience. We need some time to analyze your issue and will get back to you as soon as possible. Please wait a moment.
We apologize for the inconvenience again.
Warm regards,
Dear mc85,
Are you using our example? My test here shows no offset. Could you please send us photos and code to take a look? P4 is a relatively new product, and official support for it is still incomplete.
Warm regards,
Narrowed down the issue once you enable mqtt it will not boot. Using example esphome configuration and just add the basic mqtt configuration below.
mqtt:
broker: 192.168.1.200
Dear mc85,
Warm regards,
Dear mc85,
Regarding issues with flashing the firmware wirelessly, please ensure you are using a 2.4GHz Wi-Fi network and that the account credentials and password are correct. You might also want to try using a different Wi-Fi network.
Warm regards,
Even when flashing locally, if MQTT is enabling it crashes on boot. If I disable/remove the MQTT configuration I can flash locally or remotely and the device will boot fine.
Any possiblity of fixing the MQTT functionality on the HMI Advance esp32-P4 ?
