luma.led_matrix errors when building from setup.py
I have been upgrading the OS on some of my CrowPis so that I can run CircuitPython. I followed the setup instructions here: https://github.com/Elecrow-RD/CrowPi#drivers-installation, including git clone https://github.com/Elecrow-RD/CrowPi.git.
All the drivers compile, except the one in luma.led_matrix. I get lots of warnings, but errors from /usr/bin/ld that say something like: '...multiple definitions of 'brightness' ... first defined here.' 'brightness' is only an example. Can you help me out to compile luma.led_matrix?
I am using Raspbian GNU/Linux 11 (bullseye) and uname -r says '5.15.32-v71+'
Thank you.
I used https://github.com/rm-hull/luma.led_matrix and got things to compile. Where are the drivers installed? Do I need to set the Python path? Thanks.
