Connection error
I have got a 2.4 inch HMI display to experiment with- planning to use with home assistant. After various attempts I am now consistently getting connection errors wen using either IDE or ESPhome.
ESP home gives the error
Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
IDE gives Exit Status 2 - indicating a communication error.
I have tried multiple USB ports and cables in case this is the issue to no avail.
Any ideas, or do I have a faulty board?
  • edited December 2025
    Dear Customer/Sender,
    Pls provide the following :
    1. pl tell us exactly which of our products you are using. We need to know the SKU No. . Or Please provide the purchase link for the product. so that we can continue to analyze the issue
    2. Also, please provide the order number, product purchase link(if applicable), along with the name of the retailer, store, platform, or website where you purchased the product?
    Quote
  • Hi, its SKU: DIS03024H001
    Purchased direct from the Elecrow website order no 267993
  • edited January 6
    Dear gmarshall387,
    Please download the firmware to your device first (factory firmware link below) and see if it works normally. This will help you confirm that the hardware is functioning correctly:
    https://github.com/Elecrow-RD/CrowPanel-2.4-ESP32-HMI-320x240/tree/master/factory_firmware
    Please also send us a screenshot or photo of the error messages that appeared in your end.
