CrowPanel 1.28inch Rotary Encoder Reports Wrong Direction
I've just received my CrowPanel 1.28inch Rotary Display, and found that when using the pre-loaded example demo the rotary encoder turning the knob only works correctly in one direction. This is also true for the "Encoder_code" example provided by the wiki, which I've used to do most of the testing since I noticed this issue.
When turning the knob to the left the Serial Monitor shows CW for each physical click I feel, as expected.(I would call it counter-clockwise but I suppose either perspective is valid.) When turning the knob the other way, it shows either CW as often or more often than the expected CCW. The knob only consistently shows CCW when turned very slowly in that direction, and when turned quickly it reports almost all incorrect CW.
Is there anything that can be done to fix this error? Is my unit defective? Thank you for your help.
  • Dear alexare,
    Pls see if this method woorks:
    Please fix the bottom and then rotate it.
    Warm regards,
