Elecrow 8.8 inch Display IPS LCD HDMI with RPi5
Problem communicating with RPi5.Problem with communication with the RPi5. After starting the RPi5, the display only lights up. There is no image. After disconnecting the HDMI cable from the board (without turning the RPi5 off) and reconnecting it, an image appears. After turning the RPi5 off and on again, the problem remains the same. I have to disconnect the HDMI cable again, reconnect it, and the display comes to life. How to solve this? This display is compatible with the RPi. The operating program is RPi OS 64-bit.
Thank You for any help.
  • edited October 2025
    This Elecrow 8.8-inch IPS LCD is a solid choice for Raspberry Pi 5 projects! The HDMI connection makes setup super simple, and the wide viewing angles plus crisp color reproduction look impressive for such a compact display. Perfect for dashboards, mini PCs, or embedded system builds.
  • Dear Wiltost,
    Please shoot a video and send it to us so that we can further analyze the issue. The video should include the complete operation/test process as well as the problem/fault phenomenon.
    if the video is too large, pls upload it to a platform(like Google Drive), then send the link to us.
    Warm regards,
