ESP32 4.3" panel black screen
Hello guys. this i getting when running from this code #include <lvgl.h>
include <SPI.h>
include <Arduino_GFX_Library.h>
include "ui.h"
//4.3
define SD_MOSI 11
define SD_MISO 13
define SD_SCK 12
define SD_CS 10
define I2S_DOUT 20
define I2S_BCLK 35
define I2S_LRC 19
define BUTTON_PIN 38
define TFT_BL 2
define GFX_BL DF_GFX_BL // default backlight pin, you may replace DF_GFX_BL to actual backlight pin
if defined(DISPLAY_DEV_KIT)
Arduino_GFX *lcd = create_default_Arduino_GFX();
else /* !defined(DISPLAY_DEV_KIT) */
//UI
int led;
SPIClass& spi = SPI;
Arduino_ESP32RGBPanel bus = new Arduino_ESP32RGBPanel(
GFX_NOT_DEFINED / CS /, GFX_NOT_DEFINED / SCK /, GFX_NOT_DEFINED / SDA /,
40 / DE /, 41 / VSYNC /, 39 / HSYNC /, 42 / PCLK /,
45 / R0 /, 48 / R1 /, 47 / R2 /, 21 / R3 /, 14 / R4 /,
5 / G0 /, 6 / G1 /, 7 / G2 /, 15 / G3 /, 16 / G4 /, 4 / G5 /,
8 / B0 /, 3 / B1 /, 46 / B2 /, 9 / B3 /, 1 / B4 /
// option 1:
// ILI6485 LCD 480x272
Arduino_RPi_DPI_RGBPanel *lcd = new Arduino_RPi_DPI_RGBPanel(
bus,
480 / width /, 0 / hsync_polarity /, 8 / hsync_front_porch /, 4 / hsync_pulse_width /, 43 / hsync_back_porch /,
272 / height /, 0 / vsync_polarity /, 8 / vsync_front_porch /, 4 / vsync_pulse_width /, 12 / vsync_back_porch /,
1 / pclk_active_neg /, 7000000 / prefer_speed /, true / auto_flush */);
endif /* !defined(DISPLAY_DEV_KIT) */
Please config the touch panel in touch.h
include "touch.h"
/* Change to your screen resolution */
static uint32_t screenWidth;
static uint32_t screenHeight;
static lv_color_t disp_draw_buf[480 * 272 / 8];
/* Display flushing */
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
uint32_t w = (area->x2 - area->x1 + 1);
uint32_t h = (area->y2 - area->y1 + 1);
if (LV_COLOR_16_SWAP != 0)
lcd->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
else
lcd->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
endif
lv_disp_flush_ready(disp);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
if (touch_has_signal())
if (touch_touched())
/*Set the coordinates*/
data->point.x = touch_last_x;
data->point.y = touch_last_y;
Serial.print( "Data x :" );
Serial.println( touch_last_x );
Serial.print( "Data y :" );
Serial.println( touch_last_y );
else if (touch_released())
else
void setup()
Serial.begin( 9600 ); /初始化串口/
pinMode(38, OUTPUT);
digitalWrite(38, LOW);
pinMode(0, OUTPUT);//TOUCH-CS
//lvgl初始化
lv_init();
// Init Display
lcd->begin();
lcd->setTextSize(2);
lcd->fillScreen(BLACK);
//触摸初始化
touch_init();
//setTouch(calData);
screenWidth = lcd->width();
screenHeight = lcd->height();
lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight / 8);
/* Initialize the display /
lv_disp_drv_init(&disp_drv);
/ Change the following line to your display resolution */
/* Initialize the (dummy) input device driver */
delay(300);
ifdef TFT_BL
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
endif
ui_init();//开机UI界面
lv_timer_handler();
void loop()
lv_timer_handler();
if(led == 1)
digitalWrite(38, HIGH);
if(led == 0)
delay(50);
. There error came out from serial is ELF file SHA256: d74180a4c23e9789
Rebooting...
����-�( ��L�9c�q�Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x4037dd14 PS : 0x00060833 A0 : 0x803809a0 A1 : 0x3fcebb80
A2 : 0xbfcf8394 A3 : 0xb33fffff A4 : 0x0000cdcd A5 : 0x00060823
Dear Customer,
We have received your messages, and our technical support team is reviewing the details. Please allow us some time to look into the matter. We will get back to you as soon as possible with an update.
Dear Customer,
Pls view the following :
May I ask exactly which of our products you are using? We need to know the SKU No. . Or Please provide the purchase link for the product, so that we can continue to analyze the issue
Also, could you please provide the order number, along with the name of the retailer, store, platform, or website where you purchased the product?
Our company currently requires this information when requesting technical support. This allows us to work with the seller to provide you with better service.
Warm regards,
