is ThinkNode-M1 equipped with geo-fencing
Question:
CIL12901M I am interested in yr ThinkNode-M1, and wonder if it could work as antitheft device outside of the area covered by celphone network. Questions: is yr device equipped with geo-fencing, ie if it is moved out it's position by more than say 5 m radius it will generate an alarm< - can this alarm be send say 200 m to one of yr devices which will be at my home? can it work as LoRa rather than via celphone system, will I need two of yr transceivers, one as position sensor with GPS geo-fencing to generate alarm if moved outside of radius and the other as receiver to pick up this alarm
Answer:
As you mentioned, you can use two devices to achieve this function. The hardware of this device is capable of supporting it. However, our factory firmware does not support electronic fences function. You will need to develop the firmware yourself. Since the software of this device is not open source, I'm sorry that we are unable to provide in-depth technical support for your firmware development.
