Minecraft
Hello, I am thinking of ordering the new crowPie2 laptop. I have some questions. Minecraft. How exactly can someone craft buildings? Can I use this later on, in the actual Minecraft? (as a seed or any other way) Does it connect to Minecraft or is it only on the elecrow laptop? Can you play Minecraft or has a limited function?
  • The answer to your question is as follows.
    1. Those craft building entities have RFID tags added inside them and need to be paired with Crowpi2's RFID identification module to function, so they won't work on other actual Minecraft. We haven't tried to find out if it's possible to save seeds or anything like that, so maybe you can give it a try!
    2. Generally, if you have the same version number, you can connect, but you will need to find out how to do so.
