CrowVision 11.6" max resolution
Hello All,
I have checked CrowVision it says its resolution is 1366x768 . so is this the max resolution that can be supported by this display? or it can also support higher resolution also (like 1920x1080)?
  • Dear nil,
    I am sorry that 1366x768 is the highest resolution for this device.
  • nilnil
    edited June 28
    when i connect this to my embedded x86 board it shows 1920x1080 resolution. I just want 1366x768 default resolution. my board have DVI output so i have connect DVI to hdmi adaptor and then to CrowVision display.
  • Dear Jennie,
    is it possible to modify the EDID memory on board so that display will only support for 1366x768?
  • nilnil
    edited June 29
    I have also tried with another board having HDMI output (so no any display converter required) still Ubuntu shows 1920x1080 resolution option.
  • Dear nil,
    Hope you are doing well. Thank you for the update .
    Thanks! Have a nice day!
