touchscreen feature does not seem to be working well
I recently purchased your 5 inch lcd touchscreen display for raspberry pi and while it works great for the most part the touchscreen feature does not seem to be working well at all. It seems accurate with the pen at the centre of the screen but becomes more inaccurate towards the edge, with it being around an inch out right at the edge. I've installed and used the calibration software correctly but it's still faulty. Any ideas on how to fix this?
  • you will need to make the following adjustments
    1、Install Xinput, execute the following command code in the Raspberry Pi
    (Note: This installation requires the Raspberry Pi to be connected to the network)
    sudo rm -rf LCD-show
    git clone https://github.com/goodtft/LCD-show.git
    chmod -R 755 LCD-show
    cd LCD-show/
    sudo dpkg -i -B xinput-calibrator_0.7.5-1_armhf.deb
    2、Execute the touch calibration command
    DISPLAY=:0.0 xinput_calibrator
    At this time, the screen will pop up the touch calibration interface, use the touch pen to click on the four calibration points to complete the calibration
    After the calibration is completed, the new touch parameters will be displayed (different LCD types, different calibration times, parameters will also be different).
    As shown in the figure below:
    3、Modify the calibrated touch parameters and save them
    3.1 Open the 99-calibration.conf file by executing the following command code
    sudo nano /etc/X11/xorg.conf.d/99-calibration.conf
    3.2 Save the calibrated touch parameters in the 99-calibration.conf file
    Press Ctrl+X to exit.
    3.3 Press the Y key to confirm the save.
    3.4 Press Enter to confirm the save file name.
    3.5 Reboot the Raspberry Pi
