CrowPi micro-USB unable to charge
Question: The micro USB connector which connecting the onboard power supply circuit is not fit to connect the Pi 3 port. Which is upside down and making the pi3 not able to mount on the broad. Is there any solution to this?
Answer: The Mini USB connector is not to use for the power supply. Only use The Mini USB connector when you use PI zero on the crowpi. crowpi can supply power for both crowpi and the PI.
