Having adjusted to the correct PINs i encounter WAV files are not playable via I2S neither STERO nor MONO .
It crashes with
Guru Meditation Error: Core 1 panic'ed (IntegerDivideByZero). Exception was unhandled.
Hi oliver,
Our technical support team is currently looking into your issue in your post. Please be patient, and we will get back to you as soon as possible.
If you have any additional questions, feel free to ask us.
By the way even the sample code in the Tutorial "Play music" throws the error "Invalid Pin"
It crashes with
Hi oliver,
Hi Oliver,
Regarding your issue, please refer to the image below and try the following code(please put the code in an .ino file).
