Additional connector on next version of Crowpanel
Hi,
I think I posted in the wrong section...so this is a repeat
I use the CrowPanel (5 and 7 inch versions) for my product. I use the panel with a CAN bus, I configure the TWAI driver to use (on the Advanced series) IO4 and IO5, on the standard series I use IO17 and IO18.
These are the I2S GPIO's on both boards and I use them as I have no need for the I2S driver.
Would it be possible to add a connector (horizontal like the BAT connector on the Advance board) with these IO ports? Even better, a connector with 4 pins for +5V, GND and the 2 IO ports.
At the moment I have to solder wires to the board.
I see on the Advanced board that the IO43 and IO44 are available on 2 different connectors, UART0-OUT and UART0-IN so it doesn´t even need an extra connector, just a different style of connector (horizontal rather than vertical).
  • Hi Acuario,
    Thank you for your suggestions. We will record them and carefully consider them for future updates.
    Additionally, Both of our displays support customization. If you have bulk requirements, we can make changes for you. You can contact this email: wilson@elecrow.com.
    If you have any other questions, please feel free to ask.
