Strange behaviour Crow Panel HMI Advanced 7inch Lesson4 - displaced sccreen
Hello.
I'll say right away - I'm a complete beginner..
I have a Crow Panel Advanced HMI 7 inch panel in my tests.
During lesson 4 - photos from SD CARD - the photos are loaded but the image is shifted a few dozen pixels to the left. I hope you can see it well in the photos I'm attaching.
The panel resolution is set correctly - I'm attaching the code
Second thing - with the standard parameter
cfg.freq_write = 21000000; the image flickers when loading - it's like it's waving.
After setting cfg.freq_write = 14000000; - everything is ok
Setting below 14 only causes a white screen
SD_CrowPanel_ESP32_Advance_HMI_4_3_5_0_7_0.ino
#include "pins_config.h"
#include "LovyanGFX_Driver.h"
#include <Wire.h>
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
/* Expand IO */
#include <TCA9534.h>
TCA9534 ioex;
#define SD_MOSI 6
#define SD_MISO 4
#define SD_SCK 5
#define SD_CS 0 //The chip selector pin is not connected to IO
// The image name you stored on the SD card
#define IMAGE_1 "/1.bmp"
#define IMAGE_2 "/2.bmp"
#define IMAGE_3 "/3.bmp"
#define IMAGE_4 "/4.bmp"
// #define IMAGE_5 "/5.bmp"
SPIClass SD_SPI = SPIClass(HSPI);
LGFX gfx;
// Display text on the screen
void show_test(int lcd_w, int lcd_h, int x, int y, const char * text) {
gfx.fillScreen(TFT_BLACK);
gfx.setTextSize(3);
gfx.setTextColor(TFT_RED);
gfx.setCursor(x, y);
gfx.print(text);
void setup()
Serial.begin(115200); // set baud rate
// Init Display
gfx.init();
gfx.initDMA();
gfx.startWrite();
delay(500);
Wire.begin(15, 16);
delay(50);
ioex.attach(Wire);
ioex.setDeviceAddress(0x18);
ioex.config(1, TCA9534::Config::OUT);
/* Turn on backlight */Serial.println("Refreshing image...5");
ioex.output(1, TCA9534::Level::H);
if (SD_init() == 0)
Serial.println("TF_Card initialization succeeded");
show_test(LCD_H_RES, LCD_V_RES, 800, 480, "SD_Card OK");
delay(3000);
} else {
Serial.println("TF card initialization failed");
show_test(LCD_H_RES, LCD_V_RES, 800, 480, "SD_Card failed");
delay(3000);
gfx.setRotation(2);
Serial.println( "----- Setup done -----" );
void loop()
// Cycle printing each image
Serial.println("Refreshing image...1");
displayImage(SD, IMAGE_1, 800, 480);
delay(5000);
Serial.println("Refreshing image...2");
displayImage(SD, IMAGE_2, 800, 480);
delay(5000);
Serial.println("Refreshing image...3");
displayImage(SD, IMAGE_3, 800, 480);
delay(5000);
Serial.println("Refreshing image...4");
displayImage(SD, IMAGE_4, 800, 480);
delay(5000);
// Serial.println("Refreshing image...5");
// displayImage(SD, IMAGE_5, 800, 480);
// delay(5000);
// SD card initialization
int SD_init()
SPI.begin(SD_SCK, SD_MISO, SD_MOSI, SD_CS);
SD_SPI.begin(SD_SCK, SD_MISO, SD_MOSI);
if (!SD.begin(SD_CS, SD_SPI, 80000000))
Serial.println(F("ERROR: File system mount failed!"));
SD_SPI.end();
return 1;
else
Serial.println("Card Mount Successed");
Serial.printf("SD Size: %lluMB \n", SD.cardSize() / (1024 * 1024));
// hspi->end();
listDir(SD, "/", 2);
Serial.println("**** TF Card init finished ****.");
return 0;
Function: List files and subdirectories in the specified directory.
Parameters:
- fs: The file system object used to operate on the file system.
- dirname: A pointer to the name of the directory whose contents are to be listed.
- levels: Specifies the depth of recursive listing of subdirectories.
void listDir(fs::FS & fs, const char *dirname, uint8_t levels) {
Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname); // Open the specified directory.
// If the directory cannot be opened.
if (!root) {
Serial.println("Failed to open directory");
return;
// If the opened item is not a directory.
if (!root.isDirectory()) {
Serial.println("Not a directory");
return;
File file = root.openNextFile(); // Open the next file in the directory.
// While there are still files.
while (file) {
// If the current file is a directory.
if (file.isDirectory()) {
Serial.print(" DIR : ");
Serial.println(file.name()); // Print the directory name.
// If there are still levels of depth for recursion.
if (levels) {
listDir(fs, file.name(), levels - 1); // Recursively call the function to list the contents of the subdirectory, reducing the depth by 1.
// If the current file is not a directory, i.e., a regular file.
else {
Serial.print(" FILE: ");
Serial.print(file.name()); // Print the file name.
Serial.print(" SIZE: ");
Serial.println(file.size()); // Print the file size.
file = root.openNextFile(); // Continue to open the next file in the directory.
Function:wrong position 7
- Display image from file
Parameters:
- filename: The name of the BMP image file
- x: The x - coordinate on the screen to start printing the image
- y: The y - coordinate on the screen to start printing the image
Returns:
- 0 if the image is printed successfully, 0 if the file cannot be opened
int displayImage(fs::FS &fs, String filename, int x, int y)
File f = fs.open(filename, "r"); // Open the file for reading
if (!f)
Serial.println("Failed to open file for reading");
f.close();
return 0; // File open failed, return 0
f.seek(54); // Skip the 54 - byte BMP file header
int X = x; // representing the width of the image
int Y = y; // representing the height of the image
uint8_t RGB[3 * X]; // Storage space for RGB data of each row, 320 pixels, 3 bytes per pixel (RGB)
for (int row = 0; row < Y; row++) // Iterate through each row of the image
f.seek(54 + 3 * X * row); // Jump to the position of the current row
f.read(RGB, 3 * X); // Read the RGB data of the current row
gfx.pushImage(0, row, X, 1, (lgfx::rgb888_t *)RGB); // Display the data of the current row
f.close(); // Close the file
return 0;
LovyanGFX_Driver.h:
#define LGFX_USE_V1
#include <LovyanGFX.hpp>
#include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
#include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
#include <driver/i2c.h>
class LGFX : public lgfx::LGFX_Device {
public:
lgfx::Bus_RGB _bus_instance;
lgfx::Panel_RGB _panel_instance;
// lgfx::Light_PWM _light_instance;
LGFX(void) {
cfg.memory_width = 800;
cfg.memory_height = 480;
cfg.panel_width = 800;
cfg.panel_height = 480;
cfg.offset_x = 10;
cfg.offset_y = 0;
_panel_instance.config(cfg);
{Serial.println("Refreshing image...5");
auto cfg = _panel_instance.config_detail();
cfg.use_psram = 1;
_panel_instance.config_detail(cfg);
cfg.panel = &_panel_instance;
cfg.pin_d0 = GPIO_NUM_21; // B0
cfg.pin_d1 = GPIO_NUM_47; // B1
cfg.pin_d2 = GPIO_NUM_48; // B2
cfg.pin_d3 = GPIO_NUM_45; // B3
cfg.pin_d4 = GPIO_NUM_38; // B4
cfg.pin_d5 = GPIO_NUM_9; // G0
cfg.pin_d6 = GPIO_NUM_10; // G1
cfg.pin_d7 = GPIO_NUM_11; // G2
cfg.pin_d8 = GPIO_NUM_12; // G3
cfg.pin_d9 = GPIO_NUM_13; // G4
cfg.pin_d10 = GPIO_NUM_14; // G5
cfg.pin_d11 = GPIO_NUM_7; // R0
cfg.pin_d12 = GPIO_NUM_17; // R1
cfg.pin_d13 = GPIO_NUM_18; // R2
cfg.pin_d14 = GPIO_NUM_3; // R3
cfg.pin_d15 = GPIO_NUM_46; // R4
cfg.pin_henable = GPIO_NUM_42;
cfg.pin_vsync = GPIO_NUM_41;
cfg.pin_hsync = GPIO_NUM_40;
cfg.pin_pclk = GPIO_NUM_39;
cfg.hsync_polarity = 0;
cfg.hsync_front_porch = 8;
cfg.hsync_pulse_width = 4;
cfg.hsync_back_porch = 8;
cfg.vsync_polarity = 0;
cfg.vsync_front_porch = 8;
cfg.vsync_pulse_width = 4;
cfg.vsync_back_porch = 8;
cfg.pclk_idle_high = 1;
_bus_instance.config(cfg);
// auto cfg = _light_instance.config();
// cfg.pin_bl = GPIO_NUM_2;
// _light_instance.config(cfg);
// _panel_instance.light(&_light_instance);
auto cfg = _touch_instance.config();
cfg.x_min = 0;
cfg.x_max = 800;
cfg.y_min = 0;
cfg.y_max = 480;
cfg.pin_int = -1;
cfg.bus_shared = false;
cfg.offset_rotation = 0;
// I2C接続
cfg.i2c_port = I2C_NUM_0;
cfg.pin_sda = GPIO_NUM_15;
cfg.pin_scl = GPIO_NUM_16;
cfg.pin_rst = -1;
cfg.freq = 400000;
cfg.i2c_addr = 0x5D; // 0x5D , 0x14
_touch_instance.config(cfg);
_panel_instance.setTouch(&_touch_instance);
setPanel(&_panel_instance);
Sry for missing <code> i cant add it, dont know how.
