DIS08070H : CrowPanel 7.0" HMI ESP32 Display - Cannot compile with LVGL libraries
edited February 2025 in Elecrow HMI Display
Hi,
I bought a 7'' crowpanel I use ArduinoIDE 2.2. 2 to program and compile while I wanted to use the LVGL libraries.
I followed any tutorial spent hours to compile and make it work, of course the Hello World works, but I wanted to use those libraries to create a decent graphics for my project.
Any compilation with this panel fails, only some projects without lvgl work, I'm really exhausted by the thousand compilations with always the same error result and it doesn't continue as indicated in the elecrow wiki:
I followed this link:
https://www.elecrow.com/wiki/esp32-display-702727-intelligent-touch-screen-wi-fi26ble-800480-hmi-display.html#arduino-ide
https://www.elecrow.com/download/product/CrowPanel/ESP32-HMI/7.0-DIS08070H/Arduino_Tutorial/Arduino_Tutorial_70.zip
I added the libraries contained in the zip but this is the compiler result:
In file included from /home/path/arduino/libraries/lvgl/src/../src/lv_init.h:16,
                 from /home/path/arduino/libraries/lvgl/src/../lvgl.h:21,
                 from /home/path/arduino/libraries/lvgl/src/lvgl.h:16,
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui.h:13,
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui.c:6:
/home/path/arduino/libraries/lvgl/src/../src/lv_conf_internal.h:3711: warning: "LV_USE_MEM_MONITOR" redefined
 3711 |     #define LV_USE_MEM_MONITOR 0
In file included from /home/path/arduino/libraries/lvgl/src/../src/lv_conf_internal.h:58:
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/lv_conf.h:285: note: this is the location of the previous definition
  285 | #define LV_USE_MEM_MONITOR 1
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui.c: In function 'ui_event_Button1':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui.c:37:16: warning: unused variable 'target' [-Wunused-variable]
   37 |     lv_obj_t * target = lv_event_get_target(e);
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui.c: In function 'ui_event_Button2':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui.c:45:16: warning: unused variable 'target' [-Wunused-variable]
   45 |     lv_obj_t * target = lv_event_get_target(e);
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp_hook.c:6:
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_Screen1.c:6:
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp_button2.c:6:
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp_button2.c: In function 'ui_Button2_create':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp_button2.c:24:28: warning: implicit declaration of function 'lv_mem_alloc'; did you mean 'lv_realloc'? [-Wimplicit-function-declaration]
   24 |     lv_obj_t ** children = lv_mem_alloc(sizeof(lv_obj_t *) * _UI_COMP_BUTTON2_NUM);
      |                            lv_realloc
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp_button2.c:24:28: warning: initialization of 'lv_obj_t **' from 'int' makes pointer from integer without a cast [-Wint-conversion]
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp.c:6:
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp.c: In function 'ui_comp_get_child':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp.c:22:19: warning: passing argument 1 of 'lv_event_send' from incompatible pointer type [-Wincompatible-pointer-types]
   22 |     lv_event_send(comp, LV_EVENT_GET_COMP_CHILD, &info);
      |                   lv_obj_t *
In file included from /home/path/arduino/libraries/lvgl/src/../src/core/../display/lv_display.h:18,
                 from /home/path/arduino/libraries/lvgl/src/../src/core/lv_obj_tree.h:18,
                 from /home/path/arduino/libraries/lvgl/src/../src/core/lv_obj.h:24,
                 from /home/path/arduino/libraries/lvgl/src/../lvgl.h:39:
/home/path/arduino/libraries/lvgl/src/../src/core/../display/../misc/lv_event.h:124:45: note: expected 'lv_event_list_t *' {aka 'lv_array_t *'} but argument is of type 'lv_obj_t *'
  124 | lv_result_t lv_event_send(lv_event_list_t * list, lv_event_t * e, bool preprocess);
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp.c:22:25: warning: passing argument 2 of 'lv_event_send' makes pointer from integer without a cast [-Wint-conversion]
      |                         uint32_t {aka long unsigned int}
/home/path/arduino/libraries/lvgl/src/../src/core/../display/../misc/lv_event.h:124:64: note: expected 'lv_event_t *' but argument is of type 'uint32_t' {aka 'long unsigned int'}
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp.c:22:5: warning: the address of 'info' will always evaluate as 'true' [-Waddress]
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp.c: In function 'del_component_child_event_cb':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_comp.c:36:5: warning: implicit declaration of function 'lv_mem_free' [-Wimplicit-function-declaration]
   36 |     lv_mem_free(c);
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_img_on_png.c:6:
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_img_on_png.c:115:3: error: 'b' undeclared here (not in a function)
  115 |   b  .header.always_zero = 0,
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_img_on_png.c:119:18: error: 'LV_IMG_CF_TRUE_COLOR_ALPHA' undeclared here (not in a function)
  119 |     .header.cf = LV_IMG_CF_TRUE_COLOR_ALPHA,
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_img_off_png.c:6:
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_img_off_png.c:115:13: error: 'lv_image_header_t' has no member named 'always_zero'
  115 |     .header.always_zero = 0,
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_img_off_png.c:119:18: error: 'LV_IMG_CF_TRUE_COLOR_ALPHA' undeclared here (not in a function)
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.h:13,
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c:6:
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c: In function '_ui_arc_increment':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c:68:19: warning: passing argument 1 of 'lv_event_send' from incompatible pointer type [-Wincompatible-pointer-types]
   68 |     lv_event_send(target, LV_EVENT_VALUE_CHANGED, 0);
      |                   lv_obj_t *
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c:68:27: warning: passing argument 2 of 'lv_event_send' makes pointer from integer without a cast [-Wint-conversion]
      |                           int
/home/path/arduino/libraries/lvgl/src/../src/core/../display/../misc/lv_event.h:124:64: note: expected 'lv_event_t *' but argument is of type 'int'
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c: In function '_ui_slider_increment':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c:81:19: warning: passing argument 1 of 'lv_event_send' from incompatible pointer type [-Wincompatible-pointer-types]
   81 |     lv_event_send(target, LV_EVENT_VALUE_CHANGED, 0);
      |                   lv_obj_t *
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c:81:27: warning: passing argument 2 of 'lv_event_send' makes pointer from integer without a cast [-Wint-conversion]
      |                           int
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c: In function '_ui_anim_callback_free_user_data':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c:122:5: warning: implicit declaration of function 'lv_mem_free' [-Wimplicit-function-declaration]
  122 |     lv_mem_free(a->user_data);
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c: In function '_ui_spinbox_step':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c:248:19: warning: passing argument 1 of 'lv_event_send' from incompatible pointer type [-Wincompatible-pointer-types]
  248 |     lv_event_send(target, LV_EVENT_VALUE_CHANGED, 0);
      |                   lv_obj_t *
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_helpers.c:248:27: warning: passing argument 2 of 'lv_event_send' makes pointer from integer without a cast [-Wint-conversion]
      |                           int
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:2:
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:100:8: error: 'lv_disp_draw_buf_t' does not name a type; did you mean 'lv_draw_buf_t'?
  100 | static lv_disp_draw_buf_t draw_buf;
      |        lv_draw_buf_t
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:103:8: error: 'lv_disp_drv_t' does not name a type; did you mean 'lv_fs_drv_t'?
  103 | static lv_disp_drv_t disp_drv;
      |        lv_fs_drv_t
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:106:6: error: variable or field 'my_disp_flush' declared void
  106 | void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:106:20: error: 'lv_disp_drv_t' was not declared in this scope; did you mean 'lv_fs_drv_t'?
      |                    lv_fs_drv_t
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:106:35: error: 'disp' was not declared in this scope
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:106:41: error: expected primary-expression before 'const'
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:106:75: error: expected primary-expression before '*' token
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:106:76: error: 'color_p' was not declared in this scope
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:124:6: error: variable or field 'my_touchpad_read' declared void
  124 | void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:124:23: error: 'lv_indev_drv_t' was not declared in this scope; did you mean 'lv_indev_data_t'?
      |                       lv_indev_data_t
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:124:39: error: 'indev_driver' was not declared in this scope
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:124:69: error: expected primary-expression before '*' token
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:124:70: error: 'data' was not declared in this scope; did you mean 'std::data'?
      |        std::data
In file included from /home/raschi.diego/.arduino15/packages/esp32/tools/esp-x32/2405/xtensa-esp-elf/include/c++/13.2.0/unordered_map:42,
                 from /home/raschi.diego/.arduino15/packages/esp32/tools/esp-x32/2405/xtensa-esp-elf/include/c++/13.2.0/functional:63,
                 from /home/raschi.diego/.arduino15/packages/esp32/hardware/esp32/3.1.3/cores/esp32/HardwareSerial.h:49,
                 from /home/raschi.diego/.arduino15/packages/esp32/hardware/esp32/3.1.3/cores/esp32/Arduino.h:203,
                 from /tmp/arduino/sketches/472F0B3BB32A22F51C9D1E9D78D2E5D0/sketch/crowpanel-esp32-7.0.ino.cpp:1:
/home/raschi.diego/.arduino15/packages/esp32/tools/esp-x32/2405/xtensa-esp-elf/include/c++/13.2.0/bits/range_access.h:346:5: note: 'std::data' declared here
  346 |     data(initializer_list<_Tp> __il) noexcept
      |                    lv_fs_drv_t
      |                       lv_indev_data_t
      |        std::data
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino: In function 'void setup()':
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:240:26: error: 'draw_buf' was not declared in this scope
  240 |   lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight / 15); //4
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:240:3: error: 'lv_disp_draw_buf_init' was not declared in this scope; did you mean 'lv_draw_buf_init'?
      |   lv_draw_buf_init
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:243:21: error: 'disp_drv' was not declared in this scope
  243 |   lv_disp_drv_init(&disp_drv);
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:243:3: error: 'lv_disp_drv_init' was not declared in this scope; did you mean 'lv_fs_drv_init'?
      |   lv_fs_drv_init
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:247:23: error: 'my_disp_flush' was not declared in this scope
  247 |   disp_drv.flush_cb = my_disp_flush;
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:249:3: error: 'lv_disp_drv_register' was not declared in this scope; did you mean 'lv_fs_drv_register'?
  249 |   lv_disp_drv_register(&disp_drv);
      |   lv_fs_drv_register
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:252:10: error: 'lv_indev_drv_t' does not name a type; did you mean 'lv_indev_data_t'?
  252 |   static lv_indev_drv_t indev_drv;
      |          lv_indev_data_t
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:253:22: error: 'indev_drv' was not declared in this scope
  253 |   lv_indev_drv_init(&indev_drv);
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:253:3: error: 'lv_indev_drv_init' was not declared in this scope; did you mean 'lv_fs_drv_init'?
      |   lv_fs_drv_init
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:255:23: error: 'my_touchpad_read' was not declared in this scope
  255 |   indev_drv.read_cb = my_touchpad_read;
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:256:3: error: 'lv_indev_drv_register' was not declared in this scope; did you mean 'lv_fs_drv_register'?
  256 |   lv_indev_drv_register(&indev_drv);
      |   lv_fs_drv_register
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:260:3: error: 'ledcSetup' was not declared in this scope
  260 |   ledcSetup(1, 300, 8);
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/crowpanel-esp32-7.0.ino:261:3: error: 'ledcAttachPin' was not declared in this scope; did you mean 'ledcAttach'?
  261 |   ledcAttachPin(TFT_BL, 1);
      |   ledcAttach
                 from /home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_img_background_png.c:6:
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_img_background_png.c:6017:13: error: 'lv_image_header_t' has no member named 'always_zero'
 6017 |     .header.always_zero = 0,
/home/path/arduino/test-funzionanti/crowpanel-esp32-7.0/ui_img_background_png.c:6021:18: error: 'LV_IMG_CF_TRUE_COLOR_ALPHA' undeclared here (not in a function)
 6021 |     .header.cf = LV_IMG_CF_TRUE_COLOR_ALPHA,
Using library Wire at version 3.1.3 in folder: /home/raschi.diego/.arduino15/packages/esp32/hardware/esp32/3.1.3/libraries/Wire
Using library lvgl at version 9.2.2 in folder: /home/path/arduino/libraries/lvgl
Using library LovyanGFX at version 1.2.0 in folder: /home/path/arduino/libraries/LovyanGFX
Using library SPI at version 3.1.3 in folder: /home/raschi.diego/.arduino15/packages/esp32/hardware/esp32/3.1.3/libraries/SPI
Using library GFX Library for Arduino at version 1.5.3 in folder: /home/path/arduino/libraries/GFX_Library_for_Arduino
exit status 1
Compilation error: 'b' undeclared here (not in a function)
  • edited February 2025
    I installed
    Board
    • esp32 by Espressif System 3.1.3
    Lib
    • LVGL 9.2.2
    • TFT eSPI 2.5.43
    • LovyanGFX 1.2.0
    I tried to adapt ino code, but It's very difficult
  • I try to used all library on file zip Arduino_7inch.zip but every compiled got into error, there is a simple example to use lvgl library ?
    Help me please!
  • Can anyone help me? can I use the panel as a cup holder? :'(
    Hi the board version is not compatible with the library code, instead of installing esp32 by Espressif System 3.1.3, please use Espressif System 2.0.14 version. Also instead of LVGL 9.2.2, TFT eSPI 2.5.43 and LovyanGFX 1.2.0, please use library codes in this wiki page.
    Thank you Nina,
    I used the esp32 library as you mentioned, while I had deleted all the arduino libraries and copied those of the project, but the compilation failed.
    In the end I tried a mix of their libraries and Arduino's LVGL 8.4.0 and this worked with some simple compilations.
    However the example they show in the demo with lv_demo_widgets() is uncompilable. Too many errors where there are incompatibilities of libraries.
    In the end I gave the panel back because it also seems there are problems with differences in drivers between 7'', 5'' or 3.5''.
    I activated and downloaded the correct versions also by setting #define CrowPanel_70.
    Now I'll see if I can compile something of my own first and then I'll see if I can buy it again, maybe a smaller display.
    It's a shame that I'm releasing these little gems but they don't take care of the compatibility aspect with more energy.
    For example lvgl 9.2.2 changes a lot of methods and you end up with a huge headache.
