Value of L2, L3, L4 on SKU CRT01262M
Can someone tell me the value of L2, L3, and L4 on LoRaWAN Gateway Module Based on ESP32 with 1.8” LCD - 1 Channel for Long Range Communication-868 MHz. I opened the eagle files available on wiki page link below
https://www.elecrow.com/wiki/lora-basic-gateway-module.html
the Schematic file value is 120R which feel wrong as inductor value is in uH of nH.
  • Hi,this is wilson from Elecrow, I talked with the engineer and confirmed that the footprint was initially designed for an inductor. However, the R&D team eventually determined that an inductor was not necessary and that a resistor could be used instead. Therefore, we ultimately adopted the resistor surface-mount solution. We will correct the errors in the document as soon as possible.
