What is the lithium battery interface type and input voltage for ESP32 dispalys?
The type of lithium battery port is PH2.0. The input should be DC3.7v~5v.
Please check the attachment for the connector specifications.
the maximum charging current is 500mA, so the battery capacity doesn't need to be too big. Theoretically, a 2500mAh battery needs 6 hours of charging.
Hi
Question about the PH2.0 Battery Port
Can this be used to power from constant 5V DC source? ie, not using a battery, but using an LDO
Just want to make sure that there is no back-feeding from the charger circuit that might cause an issue
