1 channel LoRaWAN Gateway location settings
Hello,
I've tried setting the location of my Elecrow Lorawan gateway via the manual setting on thethings.network but after some time, the location always seems to change back to Asia. I assume this is set somewhere in the coding of the Gateway. Where might I find and adjust that to be my own location?
Thanks!
Mark
Nevermind. Found it tucked away in configNode.h. Sorry to bother.
After studying the code that I've found, I'm no longer sure that this is the code for my specific device, though the lat and lon defined in the code does match up, there are some other things that do not. Would it be possible to get a zip file containing the original code for the 1 channel gateway.
This is my model: https://www.elecrow.com/lorawan-gateway-module-based-on-esp32-1-channel-for-long-range-communication.html.
This is the code I found that I thought might be for this model:
https://forum.elecrow.com/discussion/597/lorawan-1-ch-gateway-module-based-on-esp32-issues-and-questions
Can you confirm this is the correct code? Or if not, provide the correct code?
