It says no cable and go to power saving
The laptop is connected to the CrowView via a dual type-c cable. But it says no cable and go to power saving. And the side light stays red.
  • Firstly we need to check if the type-c port of laptop supports DP (DisplayPort). If it doesn't support it then no cable will appear and go to power saving.
    A type-c port that doesn't support DP can only power CrowView. We can connect the laptop and CrowView via dual type-c cable/USB-A to type-c cable + HDMI - Mini HDMI cable, then the CrowView can be used normally.
