7 inch Display Does not run after download
Hi,
I am using Arduino 1.8.19 and I am using the A7.0 Touch.ino after uploading the program I receive this in the serial monitor after reset. Note the Screen did run A-WIFI after uploading A7.0 Touch which ran on 1st attempt but on subsequent attempts no other program will now run.
Message after BOOT + RESET on serial monitor
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x0 (DOWNLOAD(USB/UART0))
waiting for download
Message on Arduino at Start of Upload
esptool.py v3.3-dev
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32-S3
Features: WiFi, BLE
Crystal is 40MHz
MAC: ec:da:3b:97:35:58
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Arduino Message on completion of Upload
Wrote 233040 bytes (128832 compressed) at 0x00010000 in 11.5 seconds (effective 162.3 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
Message after RESET on Serial Monitor
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x43c
load:0x403b6000,len:0xbd0
load:0x403ba000,len:0x29c8
entry 0x403b61d8
E (48) gpio: gpio_set_level(226): GPIO output gpio_num error
E (58) gpio: gpio_set_level(226): GPIO output gpio_num error
E (59) gpio: gpio_set_level(226): GPIO output gpio_num error
E (64) gpio: gpio_set_level(226): GPIO output gpio_num error
  • Hello @DougWaterford ,
    Please check if the board setting is the as follows:
    And may I kindly ask which display drive you use? Is it Arduino_GFX or LovyanGFX? If it's Arduino_GFX, the version of esp32 package should be 2.0.3. Please refer to:
  • The Arduino settings are the same as your example except I am using the USB connection.
    I am trying to run the example in the ELCROW tutorial "A7.0 Touch.ino" see in bold.
    Note neither the A7.Touch.ino or the "touch.h" included library file call Arduino_GFX or LovyanGFX.
    A7.0 Touch
    #include "touch.h"
     Serial.begin( 115200 ); /*初始化串口*/
     touch_init();
     if (touch_has_signal())
       if (touch_touched())
         Serial.print( "Data x :" );
         Serial.println( touch_last_x );
         Serial.print( "Data y :" );
         Serial.println( touch_last_y );
  • Further attempts to upload result in this arduino message note the tool settings are correct.
    Chip is ESP32-S3
     File "/home/douglas/.arduino15/packages/esp32/tools/esptool_py/3.3.0/esptool.py", line 5347, in <module>
    Features: WiFi, BLE
    Crystal is 40MHz
    Uploading stub...
    Running stub...
    Stub running...
    Changing baud rate to 921600
    Changed.
       _main()
     File "/home/douglas/.arduino15/packages/esp32/tools/esptool_py/3.3.0/esptool.py", line 5340, in _main
       main()
     File "/home/douglas/.arduino15/packages/esp32/tools/esptool_py/3.3.0/esptool.py", line 4762, in main
       esp.flash_set_parameters(flash_size_bytes(args.flash_size))
     File "/home/douglas/.arduino15/packages/esp32/tools/esptool_py/3.3.0/esptool.py", line 1048, in flash_set_parameters
       self.check_command("set SPI params", ESP32ROM.ESP_SPI_SET_PARAMS,
     File "/home/douglas/.arduino15/packages/esp32/tools/esptool_py/3.3.0/esptool.py", line 495, in check_command
       val, data = self.command(op, data, chk, timeout=timeout)
     File "/home/douglas/.arduino15/packages/esp32/tools/esptool_py/3.3.0/esptool.py", line 468, in command
       p = self.read()
     File "/home/douglas/.arduino15/packages/esp32/tools/esptool_py/3.3.0/esptool.py", line 413, in read
       return next(self._slip_reader)
    StopIteration
    An error occurred while uploading the sketch
  • I have tested the USB-Arduino connection with ESP32 DEV1 board no problems. I have a second unit but am reluctant to use it in case i have the same these were both purchased from ELCROW the last month.
  • After a sometime and in desperation I tried a higher upload baud rate and it worked I had been using 921600 and 115200 but then tried 230400 with success.
