7 INCH ESP32S3 DISPLAY using USB and UART0 for serial communications
Just looking for a quick code sample that shows how to setup serial communications for UART0. I know it is simple, but I'm unable to get it working correctly. Also, am I correct in seeing that one cannot use both USB RX and UART0 RX. I would like to take different actions if data comes in from USB vs UART. If not possible, I'll find a way to deal with it.
  • No. It is not possible to take different actions depending on if the data comes from the USB or the UART plug. They both use the same UART.
