What are the correct setting (pins) to put into the tft_espi files and display type. There are no correct examples for the 5 or 7 inch which have different controllers
I plan to use LovyanGFX with it, and based on my experience getting a couple of other Elecrow screens configured, and the Arduino_GFX config, I expect this to work:
@bbrook Hello there,
The driver library for 4.3-5.0-7.0-inch screens is not TFT_eSPI, but Arduino_GFX. Because these three screens are not SPI screens, but RGB screens.
Here are the links to the libraries for the three screens:
4.3-inch: https://drive.google.com/drive/folders/1EvlF0pDCMNra8kJZh4xRMjURbQ5PMZgo?usp=sharing
5.0-inch: https://drive.google.com/drive/folders/13Dc2WL0dZWq6ObegB3QwAzsPL9LZnCm-?usp=sharing
7.0-inch: https://drive.google.com/drive/folders/1ErqUf6u7qFaZTYgHWOLuTET5P0ZY3BIA?usp=sharing
I don't have the 5" screen yet, but I have one on the way. The display was recently added to the list of devices in the Arduino_GFX examples.
These are the settings used:
class LGFX : public lgfx::LGFX_Device { public: lgfx::Bus_RGB _bus_instance; lgfx::Panel_RGB _panel_instance; lgfx::Light_PWM _light_instance; lgfx::Touch_GT911 _touch_instance; LGFX(void) { { auto cfg = _panel_instance.config(); cfg.memory_width = 800; cfg.memory_height = 480; cfg.panel_width = 800; cfg.panel_height = 480; cfg.offset_x = 0; cfg.offset_y = 0; _panel_instance.config(cfg); } { auto cfg = _bus_instance.config(); cfg.panel = &_panel_instance; cfg.pin_d0 = GPIO_NUM_15; // B0 cfg.pin_d1 = GPIO_NUM_7; // B1 cfg.pin_d2 = GPIO_NUM_6; // B2 cfg.pin_d3 = GPIO_NUM_5; // B3 cfg.pin_d4 = GPIO_NUM_4; // B4 cfg.pin_d5 = GPIO_NUM_9; // G0 cfg.pin_d6 = GPIO_NUM_46; // G1 cfg.pin_d7 = GPIO_NUM_3; // G2 cfg.pin_d8 = GPIO_NUM_8; // G3 cfg.pin_d9 = GPIO_NUM_16; // G4 cfg.pin_d10 = GPIO_NUM_1; // G5 cfg.pin_d11 = GPIO_NUM_14; // R0 cfg.pin_d12 = GPIO_NUM_21; // R1 cfg.pin_d13 = GPIO_NUM_47; // R2 cfg.pin_d14 = GPIO_NUM_48; // R3 cfg.pin_d15 = GPIO_NUM_45; // R4 cfg.pin_henable = GPIO_NUM_40; cfg.pin_vsync = GPIO_NUM_41; cfg.pin_hsync = GPIO_NUM_39; cfg.pin_pclk = GPIO_NUM_0; cfg.freq_write = 16000000; cfg.hsync_polarity = 0; cfg.hsync_front_porch = 40; cfg.hsync_pulse_width = 48; cfg.hsync_back_porch = 40; cfg.vsync_polarity = 0; cfg.vsync_front_porch = 1; cfg.vsync_pulse_width = 31; cfg.vsync_back_porch = 13; cfg.pclk_active_neg = 1; cfg.de_idle_high = 0; cfg.pclk_idle_high = 0; _bus_instance.config(cfg); } _panel_instance.setBus(&_bus_instance); { auto cfg = _light_instance.config(); cfg.pin_bl = GPIO_NUM_2; _light_instance.config(cfg); } _panel_instance.light(&_light_instance); { auto cfg = _touch_instance.config(); cfg.x_min = 0; cfg.x_max = 799; cfg.y_min = 0; cfg.y_max = 479; cfg.pin_int = -1; cfg.pin_rst = -1; cfg.bus_shared = false; cfg.offset_rotation = 0; cfg.i2c_port = I2C_NUM_1; cfg.pin_sda = GPIO_NUM_19; cfg.pin_scl = GPIO_NUM_20; cfg.freq = 400000; cfg.i2c_addr = 0x14; _touch_instance.config(cfg); _panel_instance.setTouch(&_touch_instance); } setPanel(&_panel_instance); } };Ignore the LovyanGFX settings I posted above - I had based them on the wrong source template and they don't work. Working settings are here.
