newest firmware
When attempting to boot my new crowpi2 with Raspberry pi 4b it gave an error that the board required newer software/firmare. I followed another post for updating the crowpi2 drive but the download fails after about 50% and tells me it is forbidden. Does anyone have a link that works, The SD has been formatted and I have nothing.
  • Are you following the download link posted in the CrowPi2 FAQs as in below,
    https://forum.elecrow.com/discussion/84/where-can-i-download-the-crowpi2-latest-image#latest
  • Having trouble downloading the firmware file, try follow my workaround solution in my post below,
  • Tried to download the latest firmware files from https://drive.google.com/drive/folders/1ViXk3Yhch0d6HS5PjDRcjfllh7VhTTQK, but it sadly doesn´t work. The file is simply too large. The download is constantly aborted. I tried with raspberry Pi, windows and my andoid tablet. None of my devices is able to download the complete file,
  • This is an embed external element. It can be deleted using the delete key or the backspace key. To view the full element, press the preview button below.
    Google Drive let me download half of the file and then stops saying not allowed. I'm very confused ...
  • @Natas
    Hello, the image file of crowpi2 has a total size of 15G, please check if your disk still has enough space.
    lol, my second PI is booting and running from a 128G SSD and yes, the root partition was resized to the hole SSD space by using gparted. So there is more than enough space for the download.
    Google drive says file is only 8G large and download is aborted after about 4.2G or so,saying network error, something is wrong here.
    I am still not able to download the file.
    Maybe someone is able to split the file into several parts, and share it as it was done here: https://www.crowpi.cc/pages/download-crowpi-series-os-image with an older version from 2022.12.14?
