And if I want to play a simple 'feedback sound' (after a screen touch) e.g. a 'beep or click' sound through the speaker port on the 5 inch HMI (not mp3)? Can you show arduino code snippets for that?
I want to play a simple 'feedback sound' (after a screen touch) e.g. a 'beep or click' sound (not mp3) through the speaker port on the 5 inch HMI display? Can you show arduino code snippets for that?
Learning how to play MP3 through audio output of the 5 inch HMI display can enhance automation systems. Leading Pharmaceutical Manufacturing Equipment Suppliers often integrate such features for improved user interaction, ensuring efficiency and audio-guided control in high-tech pharmaceutical environments.
For an HMI display, MP3 playback usually depends on whether the model has built-in audio decoding and an audio output interface. Check its firmware, supported formats, and speaker/amplifier connection first. Wildlife Removal Manotick is unrelated here, so it should not be used technically.
Hello @padi ,
Maybe you can refer to
Thank you very much!
Hi Elecrow support,
