🔥Good news! CrowPi 3 is now live on Kickstarter! Back it and enjoy the Super Early Bird (30% OFF)!
📢 Super exciting news!
CrowPi 3——Your Al Learning and Development Station. It is now live on Kickstarter!
Want to build a voice assistant? Launch an IoT project? Learn Python from scratch? It’s all possible—no experience required. Just pure learning—anytime, anywhere! 😃
👇Back CrowPi 3 now and enjoy the Super Early Bird discount (30% OFF) !
https://www.kickstarter.com/projects/elecrow/crowpi-3-an-open-source-al-education-and-development-station?ref=4todow
This All-in-One Learning Tool puts the power of Raspberry Pi 5, various plug-and-play modules, and real-time AI tools directly into your hands.
✅Supports today’s most popular LLMs — including ChatGPT, LLaMA, Gemini, DeepSeek, and more.
✅Compatible with Raspberry Pi, micro:bit, Raspberry Pi Pico, and Nano-form-factor boards.
✅41 Built-in Modules, 180+ Course Resources, 20+ Hands-on Projects
✅Supports Al Chat, Al Detection & Tracking, AI Image and Video Generation, Al Hardware Control, Al Programming, Build DIY project, etc.
  • I received mine a couple of days ago. You need to buy a keyboard and monitor. The internal monitor isn’t large enough to do any programming.
  • I tried to connect an external monitor to the CrowPi3 so I can work with the system. Unfortunately, it doesn’t work. What do I need to configure so that an external monitor connected via the HDMI port works? The built-in display is far too small for working. Thanks.
    Dear Sevener,
    How did you connect the monitor? Could you provide some photos or videos? Normally, just connecting it with an HDMI cable is sufficient and no settings are required.
    Thanks!
    Best regards,
  • photo1: you see how i connected the hdmi cable to the crwopi. If i connect the cable to my laptop it runs without any problems.
    photo2: when i put the hdmi cable into the crowpi and activate the monitor i get the message "input hdmi".
    photo3: after some seconds i get the message: no signal detected.!
    Dear Customer,
    We have received your email, and our technical support team is reviewing the details. Please allow us some time to look into the matter. We will get back to you as soon as possible with an update.
    Best regards,
    Dear Sevener
    Please open the case containing the Raspberry Pi on the back of the device, and then check if the wiring between the Raspberry Pi and other components is stable.
    Thanks!
    Best regards,
  • edited December 2025
    Thank you for pointing that out. That was the problem. Now it's working perfect. Thanks a lot.
    kindest regards
    kindest regards
    You are welcome.
    Best regards,
  • edited June 22
    In this
    Alight Motion Pro Apk does, what the mod version unlocks, how to safely download and install it, and how to use it like a pro. I have personally tested Alight Motion Apk on multiple Android devices, and everything you read here comes from real experience.
