CrowPanel 7" inch - can we use esp-idf without arduino?
ESP-IDF has support for RGB panel - see example. Is it possible to use this example with the 7 inch display??
The dimensions in the example are also 800x480. I would like to avoid using Arduino.
Hello @anujdeshpande ,
Thanks for your sharing. Please refer to this example: https://www.elecrow.com/download/product/ESP32_Display/7.0inch/ESP-IDF_7.0.zip
@Elecrow That uses arduino-esp32.
The RGB panel library provided by Espressif might not support the driver use in the CrowPanel 7.0'' display(EK9716BD3 & EK73002ACGB).
I was able to get it working with the rgb_example in esp-idf @Elecrow . I think you can update your wiki as well so that other folks can use ESP IDF directly without resorting to Arduino-IDF
You can find it here - https://github.com/espressif/esp-idf/tree/master/examples/peripherals/lcd/rgb_panel
I needed to make a few changes
Thank you for your feedback. I have forwarded your message to the engineer and we will update the wiki after we update the demo code. Thanks again for your help!
Sow how users can obtain currently ScanLine as Getscanline() function?
