CrowPanel ESP32 5" - Compiling Error
Hi,
im currently using the Esp32 5" v3 Display and trying to get the example code running on PlatformIO.
I followed the 5-inch ESP32 Dispaly PlatformIO Tutorial.
I also downloaded the example code, but i didnt get it run.
This is the Compiler Terminal output:
Building in release mode
Compiling .pio\build\esp32-s3-devkitc-1-myboard\lib099\LovyanGFX\lgfx\Fonts\IPA\lgfx_font_japan.c.o
Compiling .pio\build\esp32-s3-devkitc-1-myboard\lib099\LovyanGFX\lgfx\Fonts\efont\lgfx_efont_cn.c.o
Der Befehl "xtensa-esp32s3-elf-gcc" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
Compiling .pio\build\esp32-s3-devkitc-1-myboard\lib099\LovyanGFX\lgfx\Fonts\efont\lgfx_efont_ja.c.o
*** [.pio\build\esp32-s3-devkitc-1-myboard\lib099\LovyanGFX\lgfx\Fonts\IPA\lgfx_font_japan.c.o] Error 1
*** [.pio\build\esp32-s3-devkitc-1-myboard\lib099\LovyanGFX\lgfx\Fonts\efont\lgfx_efont_cn.c.o] Error 1
*** [.pio\build\esp32-s3-devkitc-1-myboard\lib099\LovyanGFX\lgfx\Fonts\efont\lgfx_efont_ja.c.o] Error 1
================================================================= [FAILED] Took 13.18 seconds =================================================================
Maybe someone can help me with this?
best regards MrRobot
HI MrRobot,
Please tell us exactly which of our products you are using. We need to know the SKU No. . Or Please provide the purchase link for the product. so that we can continue to analyze the issue
Best regards,
Hi Jennie,
SKU: DIS07050H
Sorry i dont get very long Amazon link in here, but i buyed it at Amazon Germany, ELECROW ESP32 Display, 5.0 Zoll HMI Display 800x480 RGB TFT Touchscreen Monitor Kompatibel mit AR duino/LVGL
Retailer is BudpawEU.
At the backside is the CrowPanel Logo and "ESP32 Display-5 Inch"
also the SKU number.
I think its a problem with the library or the PlatformIO IDE.
In meantime i reinstalled VS Code + PlatformIO, but still have problems.
thank you for your help, best regards
Dear MrRobot,
Best regards,
Dear MrRobot,,
This error indicates that the toolchain-xtensa-esp32s3 tool is missing in the compilation environment. This might be due to an improper setup during the environment creation process. It is recommended to re-establish the platformIO environment and then conduct the test again.
Best regards,
