Adding CANBUS to ESP32 HMI
I need to add CANBUS to a 7 to 10 inch ESP32 HMI. I realize this is not included from the factory and I would need to add a canbus transceiver. But are any of the ESP32 CANBUS capable pins brought out to connectors? Even if I need to disable the normal functionality for those connectors.
  • Dear Customer/Sender,
    In addition, for technical issues, we also recommend you can try to refer to the Elecrow WIKI website (https://www.elecrow.com/pub/wiki/index.html) or the Elecrow forum (https://forum.elecrow.com/) to find relavant information. Or you can search online or ask AI(like Chatgpt).
    Best regards,
  • Dear Automate,
    The pins on the interfaces of the three devices (7, 9, and 10.1 inches) are not multiplexed and can all be used independently.
    Thanks!
    Best regard,
