Problems when any I2C sensor is connected to I2C connector.
I have a BH1750 I2C sensor connected to the I2C connector of 7" V3.0 HMI.
This model has SDA=19 & SCL = 20. (no other pins are available)
The senor works fine in a standalone code (no LVGL)
But with LVGL included, the sensor stops reading, and the entire code is laggy.
Can anyone tell me whats happening?
  • Dear Customer/Sender,
    We have seen your messages, and our technical support team is reviewing the details. Please allow us some time to look into the matter. We will get back to you as soon as possible with an update.
    Best regards,
  • I found the issue.
    I need to use Wire1 instead of Wire.
    Unfortunately,this mentioned NOWHERE in your documentation.
