GrowCube moisture sensor calibration
Just installed a GrowCube and I have a sensor which is not reading correctly. The sensor appeared to be reading very low compared to the others. 28% compared to the 58% +/- on the others. Tried cleaning the contacts at the plug and got no improvement. Read a few postings here and saw there should be a moisture reading over 90% if emersed in water. Put all of the sensors in different containers with tap water and got readings of 95%, 95%, 65% and 95%, the 65% being the sensor which reads low in soil too.
It appears one sensor is faulty, however if there were a way to calibrate the sensor it might be useable still.
I suspect the only solution to my problem will be getting a replacement sensor, how would I do that if calibration is not possible?
  • Dear Customer/Sender,
    We have received your email, and our technical support team is reviewing the details. Please allow us some time to look into the matter. We will get back to you as soon as possible with an update.
    Best regards,
  • 1). SKU....... AAK45440K
    2). See the PDF attached
