GrowCube moisture sensor calibration
Just installed a GrowCube and I have a sensor which is not reading correctly. The sensor appeared to be reading very low compared to the others. 28% compared to the 58% +/- on the others. Tried cleaning the contacts at the plug and got no improvement. Read a few postings here and saw there should be a moisture reading over 90% if emersed in water. Put all of the sensors in different containers with tap water and got readings of 95%, 95%, 65% and 95%, the 65% being the sensor which reads low in soil too.
It appears one sensor is faulty, however if there were a way to calibrate the sensor it might be useable still.
I suspect the only solution to my problem will be getting a replacement sensor, how would I do that if calibration is not possible?
Dear Customer/Sender,
We have received your email, and our technical support team is reviewing the details. Please allow us some time to look into the matter. We will get back to you as soon as possible with an update.
Best regards,
1). SKU....... AAK45440K
2). See the PDF attached
Dear Rocketron55,
The description indicates one sensor is faulty. Please try swapping the connection position/interface of this faulty sensor with the other sensor and compare the results. If the problem persists, then this sensor is indeed faulty.
If the problem continues, please shoot a video and send it to us so we can further analyze the issue. The video should include the complete operation/test process as well as the problem/fault phenomenon. This is because our company policy requires such a video for returns and exchanges.
If the video is too large, please upload it to a platform (like Google Drive) and then send us the link.
Thanks! Best regards,
