Crowpanel Advance black screen after flashing firmware
Hi hope someone can help I recently purchased a crowpanel advance v1.1 with lots module
I have tried flashing Meshtastic and the device ends up with black screen and unresponsive .
So I tried flashing the example weather station example from the elecrow website and that does the same thing black screen no response.
The only thing that works with this device is the stock firmware from GitHub ?
Is this a issue with the device or something I am doing wrong ?
Many thanks for any help or advice
crowpanel Advance 5 v1.2
Apparently Meshtastic was built for v1.0 crowpanel and v1.1 crowpanel the pinouts have changed
That is why I had a blank screen.
If you require your crowpanel to support Meshtastic you would need v1.0 crowpanel.
Hopefully v1.1 will be supported soon
I am sorry . This> @Mksmiffy1 said:
You are right .
I am sorry for the inconvenience caused .
