Lazy Car
Creative inspiration:
A lazy little car, it must be knocked, it will move. Hit him and make him run.
design principle:
Free - programming drive, requires a Vibration sensor.When the vibration sensor is vibrated by knocking the module, the output is driven at a high level.
1,The Vibration sensor and the LED are connected to the power supply.
2,Connect the Vibration sensor to the LED using a Magnetic Cable.
3,Install the universal wheel.
4,Install two DC Motor.
List of materials:
Crowbits Power Supply      X 1
Crowbits Vibration Sensor X 1
Crowbits LED              X 1
Crowbits DC Motor          X 2
Magnetic Cable                    X 1
  • edited December 2025
    Interesting setup! You could also experiment with integrating simple electronics into mini gaming setups or DIY consoles. For reference on classic console BIOS and hardware for experimental projects, you can check out ps2biosonline.com to visit the site. It has detailed resources that could complement this kind of DIY electronics work.
