UART0 issue again
hi there,
I own a 5" and a 7" BASIC Elecrow Display.
They both can communicate with a "EBYTE LoRa Module"
but not with any ESP32 (AZ-Delivery / HELTEC etc) or even them thelves!
No matter with or without USB connected (separate power)
and / or with or without a level converter,
the signal does not reach ground level in theses cases.
Is there any thing I miss?
Kind Regards, hm_heli
  • Dear Customer/Sender,
    Best regards,
  • hi there,
    here's the requested info: (at least I have available)
    ordered directly at Elecrow
    order #252486 SKU DIS07050H-001 and DIS08070H-001
    order #244725 SKU DIS02050A-2-3 (not tested using UART0!)
    order #222459 SKU DIS08070H
    order #249437 SKU DIKS07050H- 001
    Best regards, hm_heli
  • Dear Customer ,
    Please provide the code and photos of the device wiring for us to analyze .
    Thanks!
    Warm regads,
  • hi there,
    Please provide the code and photos of the device wiring for us to analyze <<<
    really???
    anyway, I'm trying to send 6 fotos showing every thing but it does not allow me to post.
  • hi there,
    here are the photos..
    meanwhile I tested with an Arduino ESP32-Nano...surprise: it works!
    To me it looks like that it depends on the used USB/UART chip being used on the different ESP's and the displays.
    1. my displays do NOT talk to each other
    2. my displays do NOT talk to the larger ESP32
    3. my displays do talk to the ESP32-Nano
    4. the skope pictures show a good and a bad sinal
    5. I tested with and without a level converter
    6. the test program can't be simpler..
    Any thoughts, hints...?
    Regards
