Connect to ESP-C3 on CrowPanel-Advanced-7inch-ESP32-P4-HMI-AI-Display for WLAN
Hi,
I found no way to use the onbard ESP32-C3 for WLAN/Bluetooth so far.
I read the wiki and the lessons04 - but there was on external ESP module used - not the onboard one.
I was also not able to find a schematic or any connection diagram, where I can see where the peripherals are connected (at which IO pins)
The github link does not have the source code of demo program , which was pre-installed when I received the CrowPanel. This is sad, because I was able to connect to my WLAN using the demo, what means this source code would help a lot...
Thankful for any hint....
  • Dear Customer/Sender,
    Best regards,
  • Dear Inbux,
    We are very sorry for the inconvenience caused to you.
    The schematic diagram is now available in the GitHub link: https://github.com/Elecrow-RD/CrowPanel-Advanced-7inch-ESP32-P4-HMI-AI-Display-1024x600-IPS-Touch-Screen/tree/master/Eagle_SCH&PCB/1.0
    Our factory default routine has already configured WiFi, so users can directly use it. https://github.com/Elecrow-RD/CrowPanel-Advanced-7inch-ESP32-P4-HMI-AI-Display-1024x600-IPS-Touch-Screen/tree/master/factory_sourcecode
    The main bottom-setting pins are located here, specifically the SDIO pins:
    Thanks!
    Warm regards,
