UART0 issue again
hi there,
I own a 5" and a 7" BASIC Elecrow Display.
They both can communicate with a "EBYTE LoRa Module"
but not with any ESP32 (AZ-Delivery / HELTEC etc) or even them thelves!
No matter with or without USB connected (separate power)
and / or with or without a level converter,
the signal does not reach ground level in theses cases.
Is there any thing I miss?
Kind Regards, hm_heli
Dear Customer/Sender,
Best regards,
hi there,
here's the requested info: (at least I have available)
ordered directly at Elecrow
order #252486 SKU DIS07050H-001 and DIS08070H-001
order #244725 SKU DIS02050A-2-3 (not tested using UART0!)
order #222459 SKU DIS08070H
order #249437 SKU DIKS07050H- 001
Best regards, hm_heli
Dear Customer ,
Please provide the code and photos of the device wiring for us to analyze .
Thanks!
Warm regads,
hi there,
really???
anyway, I'm trying to send 6 fotos showing every thing but it does not allow me to post.
hi there,
here are the photos..
meanwhile I tested with an Arduino ESP32-Nano...surprise: it works!
To me it looks like that it depends on the used USB/UART chip being used on the different ESP's and the displays.
1. my displays do NOT talk to each other
2. my displays do NOT talk to the larger ESP32
3. my displays do talk to the ESP32-Nano
4. the skope pictures show a good and a bad sinal
5. I tested with and without a level converter
6. the test program can't be simpler..
Any thoughts, hints...?
Regards
Best regards,
Dear hm_heli,
Under normal circumstances, communication is possible; there are no hardware limitations between the screens.
Please refer to our example program:
Thanks!
Best regards,
