CrowPanel Advance 5 HMI ESP32 S3 Screen Tearing during OTA / WIFI
Hi,
I've got the advance 5 panel and I'm using the v1.0 "4.3_5.0_7.0_platfromIO" example
I've made no other changes except added ElegantOTA, and when I upload a new binary I get crazy horizontal screen distortions and tearing. The forum won't let me post a photo or I would
In a previous project I've tried all sorts of recommendations, changing timings, power, ram types, nothing has made any difference,
Does anyone have any ideas?
Thanks in advance
  • Dear Customer/Sender,
    Best regards,
  • edited November 2025
    Hi Jennie
    The Sku is DIS02050A-1
    The order number was from you guys: 251698
    The website won't let me post links or images, it always throws a 500, but this is part of the url on your site
    /crowpanel-advance-5-0-hmi-esp32-ai-display-800x480-ips-artificial-intelligent-touch-screen.html
    Thanks
  • Dear Horsepants,
    During WiFi OTA (Over-The-Air) updates, WiFi may: consume significant CPU resources, consume PSRAM bandwidth, enter a prolonged critical section, disable some interrupts (including those required for I80/RGB refresh), block LVGL's disp_flush, and cause DMA inter-frame refresh latency, resulting in screen tearing, horizontal distortion, jitter, and screen glitches.
    Recommended solution: Pause LVGL refresh during OTA updates.
    Thanks!
    Warm regards,
  • Hi Jennie,
    Unfortunately, I've already tried that, it made no difference. I'm beginning to wonder if the screen is faulty, it's not just a little distortion it's quite extreme, and it seems to do it on wifi in general, even when not doing OTA, just basic wifi operations. I can't embed a photo for some reason, but I've attached one
    Cheers
  • Hi Jennie,
    Any updates? Is this just expected behaviour that any wifi will distort the screen?
    Cheers
    Best regards,
  • @Horsepants said:
    Hi Jennie
    Thanks
  • edited December 2025
    @Horsepants said:
    Hi Jennie,
    Cheers
    Dear Marku,
    Sorry for the late reply .
    Please flash our factory firmware onto your device to check for screen hardware issues.
    https://github.com/Elecrow-RD/CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480/tree/master/factory_firmware
    You mentioned that the problem persists even when using only the screen and Wi-Fi. Please send us the program and a video recording. The video should include the complete operation/test process and the problem/fault phenomenon.
    If the video is too large, please upload it to a platform (like Google Drive) and send us the link.
    You may also contact us via email(techsupport3@elecrow.com) if the link cannot be pasted here.
    Thanks!
    Best regards,
