Why Thinknode M1 has no GPS signal?
2»
  • edited November 5
    @Marvin said:
    How can I correct this issue while using MeshCore?
    Is there a way to improve the accuracy?
    Dear Marvin,
    We sincerely apologize for the poor product experience.
    Please view the following:
    1. Regarding the issue of improving accuracy: Are you encountering this problem while using the Meshtastic firmware?
    If so, please try this method:
    (This problem may be caused by different map formats.)
    Please use the link below and follow the instructions in the images below. See if this resolves the issue.
    https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png
    1. Other issues you reported: We are analyzing them as quickly as possible and will reply to you as soon as we have results. Please wait some time.
      Thanks ,
    Warm regards,
    Dear Marvin ,
    May I ask if you have tried the method we provided in the last comment ? How was it? Did it work?
    Thanks!
    Best regards,
  • No; I have not tried this with Meshtastic, as I no longer use Meshtastic.
    I don't know of a way to apply this fix to a MeshCore Client node.
    Dear Marvin ,
    Thank you for the support to us .
    Sorry, we don't have a repair method applicable to MeshCore. We suggest you contact the developers of MeshCore for assistance.
    However, we recommend that you first try our solution on Meshtastic. If it works, it indicates that there is no problem with the hardware.
    Thanks!
    Warm regards,
