CrowPI-L Software Problem
Greetings:
I have a new CrowPi-L computer with modules.
I went over to the Python-Lessons-Hardware section of the software..
I followed the setup of the hardware and typed in the programs for two different programs.
I typed in the switch-light program #3 and it would not work and displayed error.
I next typed in the program for magnetic field sensor - program #5, and it would not work either.
I checked and rechecked both the wiring and the programs and they do not work.
Has anyone reported this problem.
Is there new software? that been corrected?
Please help
Thanks
Tom
  • You probably need to copy the error message to this thread, and possibly the entire code block, before anyone can help you. Then be patient, this forum is a wee bit slow...
    Chris
  • edited December 2022
    @tpetruzz Could you please post your error message? What's more, please check whether there is any content typing error or format error
  • @tpetruzz Here's the course code for #5
    import RPi.GPIO as GPIO import time GPIO.setwarnings(False) led_pin = 4 hall_pin = 5 buzzer_pin = 6 GPIO.setmode(GPIO.BCM) GPIO.setup(led_pin, GPIO.OUT) GPIO.setup(buzzer_pin, GPIO.OUT) GPIO.setup(hall_pin, GPIO.IN) while True: if (GPIO.input(hall_pin)==0): GPIO.output(led_pin, GPIO.HIGH) GPIO.output(buzzer_pin, GPIO.HIGH) time.sleep(0.5) GPIO.output(led_pin, GPIO.LOW) GPIO.output(buzzer_pin, GPIO.LOW) time.sleep(0.5) else: GPIO.output(led_pin, GPIO.LOW) GPIO.output(buzzer_pin, GPIO.LOW)
  • Here's the course code for #3
    import RPi.GPIO as GPIO import time GPIO.setwarnings(False) led_pin = 5 button_pin = 6 GPIO.setmode(GPIO.BCM) GPIO.setup(led_pin, GPIO.OUT) GPIO.setup(button_pin, GPIO.IN) while True: if GPIO.input(button_pin): GPIO.output(led_pin, GPIO.HIGH) time.sleep(0.5) GPIO.output(led_pin, GPIO.LOW)
