Games SD Card
Just received my awesome CrowPi2, the CrowPiOS SD card works fine, the Games SD card does not work.
is it a standard RetroPi install or is it specific for the CrowPi2?
Thank you
Thank you
Hello @RussellCofIdaho ,
The image in Games SD card is a standard RetroPi. You can try to reinstall RetroPi to see if it will work.
Thank you, I will do that!
WOW,
Didn't knew it was already out,Bye I am going to order this right now!
Perfect, I follow and buy a game SD card. Thanks
I have ordered the game card and it's performance is outstanding.
About the Games SD card usually, the Games card that comes with CrowPi2 is based on RetroPie, but often it’s customized specifically for CrowPi2 hardware. That might be why it’s not working properly. You could try re-flashing it with standard RetroPie or check with CrowPi support.
By the way, while you're sorting that out, if you want to relax with a fun driving game, click here to try Extreme Car Driving Simulator super fun and easy to get into!
The Games SD card that comes with the CrowPi2 is typically based on a customized version of RetroPie, tailored specifically for the CrowPi2’s hardware and pre-installed games. While it may resemble a standard RetroPie setup, it often includes additional drivers or configurations unique to the CrowPi2. If it's not working, try re-imaging the card with a fresh RetroPie build and manually add the games, or check with Elecrow for a compatible image. nulls clash
I’m also encountering the same issue — my CrowPiOS SD card works fine, but the Games SD card doesn’t boot up. Curious as well whether it’s just a standard RetroPi install or something customized specifically for the CrowPi2.
Hello, are there any specific settings or drivers in the standard RetroPi image that need to be adjusted for the CrowPi2 hardware?
